I've done a search and not been able to find any good answers to this question. Has anyone added a catalytic converter to a pre-79 FJ40 to aid in getting the truck to pass emissions? The reason I ask is I did get my 78 to pass CA emissions, but it was a bit of a struggle and had to do a lot of messing around with the truck to get it to pass. I will have to do this again in about two years and I'm looking for a way to make this a bit easier of a task. Also, something I found in this last emmissions test episode is even though the EGR is intact, present, and working, it is very hard to get the motor to stumble when it is tested ( this is a std CA test procedure ) when you have CA legal headers and a free flowing exhaust. It seems that there is not enough backpressure to force enough exhaust gas back thru the valve to make the engine stumble. A rag stuffed into the exhaust cured that for the test purposes. So, my thoughts are if I were to add an after-market CAT I would likely increase back pressure which would help with the EGR, and the CAT would improve the emmissions at the tailpipe without as much mickey-mousing with the carb, timing, etc. The truck can be made to run really well, so I hate to have to de-tune it just to pass a dang smog test. I know the state law says you have to have all the smog equipment present to pass, but I can't find anything about the addition of additional equipment. Is this even legal? All responses will be greatly appreciated, and may be of benefit to others facing the same bi-ennial ordeal. TIA
