The Electrical Tech Day has found a new home:
April 6
8:00 AM
22712 Commerce Center Ct, Dulles, VA 20166
The class will be an all day event including demonstrations and hands-on activities.
Bring your voltmeter and soldering gun, if you have one.
Lunch provided.
Here is a list of the topics I hope to cover (time will be the limiting factor):
I you have a specific topic you want to cover, please let me know so I'm prepared.
I will be bringing stuff so we can have as many hands-on experiences as possible.
Please post if you plan to attend so I know how much to print.
Hope to see you on April 6th.
Thanks to @Jakes40 for making this happen.
April 6
8:00 AM
Lunch provided.
- DC fundamentals: Volts, Amps, Ohms & Watts
- Schematic diagrams & symbols
- Switches, relays & solenoids, flashers
- Motors: permanent magnet and series wound (starter & winch motors), dynamic braking
- Ignition systems: Coil, points, distributor, wires & spark plugs
- Charging systems: Alternator/generator, Amp/Volt meter, battery & regulator
- Gauges & sensors v senders
- Dual battery options
- Wire gauge, circuit breakers, fuses, fusible links and grounding
- Crimping, splicing, soldering & shrink tube
- Troubleshooting techniques
- Tips on using a volt/amp/ohm meter
- Some unusual circuits explained
