Builds el bandito rojo (1 Viewer)
who can tell me what is unique about this one? :hmm:
All I see is a manual 4Runner.
what's wrong with this picture?
Unique? All I see is a $30,000,000 PYG left hand drive Surf. Talk about a poor economy... it is on leaf springs though
rear leaves is the unique. you guys are no fun :flipoff2:apparently ln135 is factory rear leaf. these are all typical rear link/coil.
4runner/surf are much much cheaper than hilux here.
The only other time I've seen an LN135 was in an older post on MUD. Guy was asking some questions about his Surf... here's that thread (it's not the most interesting but still cool to see foreign versions).
Nice walk around and glad to see you uploading videos again. Went thru a handful of your vids after first joining the forum. Have always found them to be helpful, informative, and entertaining.
thank you. i really appreciate it.
I think you should either post some pics here of that stock steering setup or a video. That is crazy how Toyota used that push/pull setup on those Hilux models. I can understand what you mean by the steering is not friendly.
Are you planning on converting to a crossover steering setup on the Hilux's front solid axle setup like you did on your 89 4Runner?
it's shown in the video. everyone knows whst sa push/pull looks like
You threw me off with a choke cable for a diesel. Are you using it as a throttle lock like you would for a PTO?
ya idk. toyota calls it a aux accelerator cable or something. its just a throttle opener for cold starts. these don't have pto
more "nla" parts. column cover from partsouq. this was about ten days to me. also grabbed screws and a couple dl ujoints. the local stealer wanted over $100 each for the ujoints and weren't in stock.(partsouq was $41/each) the last time I wanted to order parts they told me 50 days. as much as I want to keep my dollars local, im not letting them rape me. so there's that.
im pretty sure this is the first time I have ever had an unbroken column cover😂 not sure what's so hard about not destroying these things or honestly why the average joe ever needs to remove them. i guess some mysteries will just go unsolved.
these part numbers are for a non tilt column
