EDIC Controller build from scratch
For those of us with no electronics skills, could you guys make and sell us a version of this relay?
Pretty cool that this thread found new light. I never have had any issue with the controller since I built it and never went further. I'm interested to see what you make.
Just a quick clarification... the pnp transistors are older audio-types. my guess is they would cross with most generic pnp types such as the 3906...?
I might be interested in this too. At this point, my relay is fine. But it would be good to have a backup. Mine is an CDN spec HJ60, 24V.
I used 12v relays although the 24 might work... not sure. I could take a look at the relay specs to see if they could handle the volts.
The trasnsistors are the same you would find in an old radio. I'm not sure about the transistor part # 3906 you quoated I'd need to do some research, I'm no electronics expert by any means. For the relays depending on the quality of the manufacturing the coil part is the problem with interchanging the 12 volt and 24 volt relays. Some 24 volt relays may close at 13 to 14 volts you get from the electrical system but if you put a 12 volt relay in a 24 volt system you will break the coil after a few seconds.
Well, I for one would buy one. LMK via PM what the cost would be and I will go ahead and Paypal you. Or you can list the price publicly, it is all the same to me.
Sure! It might be a few weeks... my truck is the school I teach at, which is closed down until next week. Covid sucks on SO many levels.
Makes sense for sure. No doubt there are relays available with the same footprint but diff volts. I have a feeling the transistors I'm using will work. I think there is an off-chance one of them is NPN, using your numbers as a guide, but they are easy to swap in.
I am in no hurry but it's good to know you can help. I am looking forward to this. Will definitely purchase. Will even put down a deposit if needed.
Cheers
Hi
great thread, I would be in the market for a 12Volt version if you decide to make and sell these.
Question - is there another thread or are these being sold? A solid state one for a converted 24v to 12v BJ41 - 3b. Previous owner has the EDIC controlled on cable to the parking brake. Which I don’t like. I need a parking brake time to time.
If they aren’t being sold, I might looking to moving to a simple pull knob on the dash.
HJ 60 the set up for wire colours is:
Red = Stop
Yellow = Over inject
Green = Drive
Blue = Main Power
The wiring diagram I have for an HJ 60 shows an extra ground wire which is not on the 40 model. It could be something or it could be nothing, just the way the motor is built but controlled in the same way. Look on your relay for the part number and if they match the one I put one the wiring diagram. If it does I would gladly make you one and send it to you. It will be a while but PM me your adress and we can figure something out.
The mechanical relay parts are the weak link in the chain if you think it's failed or about to you can wire one in like this or all three for that matter. The relays I used were generic 5 pin 24volt from the auto parts store.
White Wire = Pin 86
Black wire cloest to the other Relay = Pin 85
Red = Pin 87A
Green Pin 87
other Black closest to the edge of the circuit board = Pin 30
Does this colour coding for the wires apply to the 12v version as well? I would assume so, just the colours that I have on my 2H edic are yellow, green, red and white. just trying to adapt my 2h edic to an 12ht VSV, would like to still have the low oil pressure shut off as well as the shut off with the key. cheers
Any update?
So from further research I found a wiring diagram in one of the manuals about each wire and their roles/positions that the motor uses. So in the end the green is drive, yellow is over injection(start the engine position) red is stop and the white is labeled as M which I assume is motor but will have a look at some wiring diagrams when I get home to confirm what the white is could just be ground🤙🤙
