2001LC
I did put cross-member in last. Don't recall if a actually support differential axle tube on DS, after front and rear mounts were in. I suppose one could do with cross member in, which may aid in holding up back side. It may make wrestling in position a little more difficult.
I took cross member out to de-rust. After looking at few cross members, I saw rust in same spot on each. Either these are moving around rubbing off paint, or Toyota is leaving as bare metal. If they are leaving as bare metal it would be for reasons of holding in place by "clamping force". If that's the case it's not working. Toyota does not sell the cross member alone. It comes with frame portion of mounts ~$500, which would need cutting out and welding in. So I elected to clean up and paint with POR-15, both surface (frame & cross member) as you can see. I then added ~5lb when torquing the four bolts & nuts. Replacing all the bushing, stops & mounts really tightens up the differential nicely. But if cross member moves around one my still get some shifting or driving metallic click/clunk sounds.
For simplicity I use (all - (oil, gear lube, grease and ATF)) M1 gear lube 75W-90 in all gear boxes. I find the Transfer case lube turns dark at ~20K, front diff ~25K and rear diff ~35K. I set 25K miles flush for transfer & front diff.
