Dual battery setups.
I have moved the washer bottle with Slee’s kit
I have installed the 2nd battery tray from Cdan. Did the required trimming on the fan shroud side with a cutoff tool. Wearing glasses was great advice.
Now the problem is which setup I should use. I know there are lots of setups, but I have been concentrating on the following 3 setups. These are my first impressions. I would appreciate help in making corrections and additions here.
Hellroaring, as well described by Cruiserdrew in this thread:
https://forum.ih8mud.com/showthread.php?t=36775
Painless as well described by Elmarichai in this thread:
https://forum.ih8mud.com/showthread.php?t=85505
And the Sure Power system. Cruiserhead05 has some pics of his Sure Power kit purchased from Ironpig Offroad here: https://forum.ih8mud.com/showpost.php?p=967817&postcount=2
Ironpig sells theirs as a complete kit with the tray and relocation setup. There is a local dealer for the Sure Power set-up so I would probably go there and buy the components.
So the decision comes down to which of the 3 systems do I pick. The people who have the systems are real happy and will obviously recommend what they have. So going through all the info, I thought I would come up with what the differences and capabilities are and share that for comment:
Painless Setup:
1) Configuration is completely manual.
2) You can leave everything (accessories)hooked up to the same charging circuit and swap your battery in or out to power the circuit. E.g. you don’t power your frigerator off the backup and the other stuff off the main.
3) Allows you to charge both batteries or just one (either main or back-up)
EDIT: In PM's I found Out this is not the standard way to configure but a special configuration elmariachi came up with. I believe he is going to update his thread.
4) Allows you to switch power draw to the back-up battery when parked overnight to run frigs, radio’s etc.
5) If only charging one battery, can swap to other battery if Alt fails.
Disadvantage to other set-ups I see is no automatic feature to detect a problem, bad alt or other, to isolate batteries for protection.
Advantage is cost and you configure exactly how you want it. Also, does not allow both batteries to be in charging loop when vehicle is off. This prevents forgetting to take one battery out of circuit.
Hellroaring:
Disadvantage is more expensive then painless. Does not appear you can isolate your main battery from the loads
Sure Power:
1) Automatically connects to charge both batteries when senses a charge from the alt
2) Automatically disconnects when senses no charge from the alt. So off they are disconnected.
3) Can wire your accessories like frig and other stuff you would run overnight off the back-up battery. This way you won’t run down the main. Can also wire everything to the main
4) An auxiliary start feature from the backup rig is available to allow the backup battery start the truck if the main dies. It does this automatically if it sense the main battery is dead
Advantage is backup start feature and the ability to add a switch to tie the two loads together.
Questions I have:
Painless:
Do you normally drive with switch in combine to charge both batteries, or do you isolate them to prevent something from draining both batteries while you are driving like a bad alternator?
Is there another way to see you have a bad alt before the voltage stops to drop (see on gauge)?
How long would a fully charged battery be OK if isolated from the charging circuit.
Hellroaring:
If you flip the switch to start the vehicle, is the main still in the loop potentially drawing down the main?
If your alternator is bad (Cause of dead main battery) will the backup be able to do more than just start you, can it effectively run all your electronics.
Looks like wire from backup goes to starter. Is this the wire that takes the backup battery power and powers the loads via the main battery?
Sure Power:
Again I appreciate comments. There is a lot of spec sheets and other documentation and they are not always clear.
Painless Setup:
Hellroaring:
1) Loads run off your main battery
2) Can combine both batteries for extra starting power or winching power.
3) Wire all your accessories off the main (needs to be deep cycle) If main drains, Auxilary will be swapped in via a switch to start.
4) Automatic detection of battery charge state for isolation or charging
Advantage is your backup battery has no drains so in theory, it should always be fully charged. E.g. a short on your main line could draw down your main while running the frige all night on the back-up could leave you with no good battery2) Can combine both batteries for extra starting power or winching power.
Sure Power:
Questions I have:
Painless:
Hellroaring:
Sure Power:
You're welcome to mess with my hellroaring next time we hang out, I'll second the comment that he's a cool guy as well. Only time I've ever had to use it was when I left the seat heater on for a week in the garage, but it sure was cool to flip the switch & jump myself. Man that was as
move, ok back to
