2001LC
- Thread starter
- #21
What is the slee override? isn't that if you remove the AHC stuff?
I get a stored air bag code whenever I unplug/plug the one under the passenger seat for removal. I don't remember which one exactly though. Yours is the circuit itself indicating a short I believe. You notice the x in the history column for SRS code.
• The center airbag sensor assembly receives a line short signal, open signal, short to ground signal or B+ short signal in the passenger airbag ON/OFF indicator circuit for 2 seconds. • Passenger airbag ON/OFF indicator malfunction • Center airbag sensor assembly malfunction
install a new battery and drive a while, re read codes again. if he'll let you. Sounds like a few sensors and a battery. But I know nothing of AHC.
I personally start my truck and then hook up TS and do live data checks. I've only driven with techstream hooked up one time, while I was looking at fuel and AFR stuff.
This one sounds like it's right up your alley. Hopefully he wants to ditch it for the trouble is has?
C1223 and C1241 codes..... Somewhere along the line the C1241 code set and this code means that there was low-voltage to the ABS actuator motor. This could be due to a low state of charge in the battery or the alternator not correctly putting out enough power or the battery simply being run low at some point. By default then the C1223 code sets in the traction control computer detecting a malfunction in the ABS control computer which makes sense because of the C1241 code.
I found these two when I bought mine, I had to go back and look to male sure. Then I found the above, copied from online.
So new battery might/should fix three of them.
c1718, maybe this pic helps you.
c1776 thread here, Height sensor dead in 05LX
So that one might be crummy one to deal with looks like. If he thought the accumulators were bad maybe that's why he went with the override thing.
if you need anything I have all the 06 books
Looks like you hit the nail on the head here.you shouldn't get a code at 12.7 Mine sits at 12.8 right now after sitting for three days. I find that the new stock battery likes to sit there, even for two weeks without a battery tender on it.
I would imagine, at one point yours was dead and set the code, then recharged. Unless you have a new battery that the guy put in for you.
Personally I don't mess around with batteries, if they look old or of unknown age and don't measure up I get a new one.
For me it makes it easier to determine the starter and alt condition afterward on used cars I buy.
I did find that cleaning and swapping ground straps to 4 gauge wire improved my circuit. I bet yours would benefit from cleaning all those stock lugs. Since you're going to resell it I bet it's worth trying to save that battery also.
After cleaning & greasing the very dry battery post, I gave it a full charge. Subsequently I cleared all the DTC's and they did not returned. Interesting DTC stores as a current without a CEL, and continued to show current even after full charge and multiple starts & stops. But as I said. they've not returned so I'm happy.
Looks like the boots are good, so I'll probably just re-banding. IIRC the NAPA bands are crimp so I my yet get to try the banding crimp tool on this restoration project.Let me know how that works for you
The only thing I'm still getting is a "Engine and ECT: Monitor Status; Inc, Calibration; 36065200" I'm new to using TechStream, so please excuse my ignorance, what is this?
