lumbee1
Native American
I've had an increasing issue of the drivetrain shaking when I come to a stop. Whether I hit the brakes or not, as the Cruiser come to a stop I get a deep shaking and rumble from the driveline. It does it just about everytime and is most noticable around 1400 to 1000 rpm. Sitting at idle I get what I think are the typical Cruiser shaking. The driveline doesn't seem to shake or not as bad on acceleration. Straight line driving all the way to 75mph is fine.
This problem became noticeable months ago but here some relevant work that I've done recently.
- 1 month ago axle regear. 3rds were shipped off to ECGS. While the 3rds were out, I did a full axle rebuild. Wheel bearings torqued to 25ft/lbs. No change is shaking before and after.
- 1 month ago replaced front driveshaft. I actually drove it without a front driveshaft for 50 miles. No change.
- 1 yr ago eplaced rear driveshaft U-joints. Both u-joints were replaced to fix a squeak, but this was some time ago and I don't remember if or how bad the shake was then.
- New calipers on the front, 1yr old calipers on the rear. Rotors are 1yr old
- Springs and shocks. Both springs and shocks are farily new and in great shape.
- Transfer case fluid was swapped 10k miles ago.
Suspects:
Rear TC output bearing. I don't know what a bad bearing feels like for the TC. I do not have any leaks from the TC and I've read the seal and bearing go around the same itme.
Motor mounts going bad. I guess that's a possiblity but these rarely fail and I would notice this during acceleration not decelereation.
Exhaust hangers? I've got one to take a look at these.
To elminate the rear output bearing, I am going to pull the rear driveshaft and drive without it. Hopefully there will be a huge difference and I can start fixing it.
Suspects:
