I'm going forward with my suspension replacement on my 81 40 and I've got a small problem. Front driveshaft was not on the vehicle when I purchased it, but previous owner gave me one he claimed was for the 40.
I've moved the front axle back (supported by a jack) while the springs were off. The drive shaft bolted up to the transfer case side without a problem. However, the front driveshaft bolt pattern is slightly larger vs the front axel bolt pattern (58 x 63mm). Measurements are center bolt to center bolt in a rectangle, not an "X". I'm assuming I have the wrong year driveshaft/yoke flange, but it could also be the wrong axle! Looked at pics and my axle looks stock for an 81??
I've attached pics of the axel and the yolk/driveshaft hookup.
Does someone know these details or can someone measure their bolt pattern on the front driveshaft axle side. Thanks in advance!!
CD
CD
