The front and rear circuits of the M/C have the same bore. Therefore they put out the same pressure. depending on the internal configuration and port placement, one circuit can push more volume than the other, but not more pressure.
Mark...
It is hard to make sense out of this. I'm not sure how the internals of the two-circuit work ,but I imagine that they are like two master cylinders stacked on each other sharing a common pushrod. Anyway, if the bores are the same and they are connected by a common rod, then they will put out the same pressure and volume. Volume is determined by the area and stroke of the bore. V=AxL As was said earlier MC pressure is determined by the amount of pressure put onto the pedal.
The MC can have a pressure multiplying effect on WC as long as the bore of the WC is bigger than the bore of the MC. It is pounds per square inch. So if you have an area of 1" at the MC and you put 1 pound of pressure on it and you have a WC with 2" of surface area you will get two pounds of pressure. This is the way hydraulic jacks work also. This is one of the reasons why brakes have to ride so close to their braking surface, they take up more volume than they MC can put out, because they are bigger. Even if the bore of one WC is the same you have two per wheel.
I think when people think that their rear drums are locking better, than their discs they are forgeting the mechanical advantage that the drums have. Drums are designed to push into the drum as the brake is applied where the pads in a disc system are directly proportional to the pressure behind them.
So let's see if I can apply this all to clear things up.
You have to apply more pressure to discs than to the drums to overcome mechanical advantage of drums.
You have to make sure the stroke of all WC's does not exceed the volume of the MC. This is done with adjustment on drums and back pressure on discs.
I am unclear on the way a proportioning valve works. If it only serves to slow the fluid down, than you still have the pressure problem in the drums which as far as I know can only be solved by bigger disc pistons or a bigger MC chamber for the drums.
You also have the problem of having more weight up front which again you would have to subtitute with bigger bores.
