Haha, nah, not going to be me!That's real swell of you pal. Let us know what you find.
Yeah, it definitely seems sketchy. They are cheap though!I went to the Amazons sellers web page for warranty info on the Dellas and found nothing. Tried the phone number provided and every time I called it would rings twice and go dead. Any hope or confidence on a deal is now gone![]()
I saw bad reviews on the della, so I was going to stay away, you think its worthwhile? Im almost done with my rear drawers now.80L is a big unit great price if you have the room. Dometic/Waeco has been a popular pick across the pond for a long time. I have run a Waeco for several years and have found it to be efficient with features that work for my needs.
This caught my eye Amazon.com : Della Portable Refrigerator Freezer Camping Travel Fishing RV Boat Family Cooler- 49L Capacity - 12VDC : Patio, Lawn & Garden although smaller hard to beat @$320 shipped
This likely has the same compressor as the ARB units, and based on this review below, its pullling 2.2Ah which is inline with the other top fridges on the market.
Dometic CF-80 fridge mini-review - Expedition Portal
This thing is huge! 30 beers in one of the 4 compartments![]()
Ok, so after all said and done this made the most "cents" to me anyone??
Whynter FM-45G 45-Quart Portable Refrigerator
Its an old model, it must have been around 20+ years badged as a Waeco. I have had a used one I picked up 8 years ago and it still goes well
The main gripe with mine is it is not moisture proof inside. Spilt or defrosted liquids seem to seep through joins in the plastic.
The shop that replaced the control panel had seen a quite a few do it and they charged me a small amount to thoroughly clean around the inside when they had it apart. I have a CF50 and that does not do it.
Its still a good fridge, but I would invest in some of that cloth that will soak up liquids. It has small piece of foam under that square access hatch at the bottom. Give them a clean regularly. Keep any fish or bait in its own airtight container.
It takes up a lot of floor space but its the easiest fridge to find things in.
Is this a problem or a good thing? LOL
Did you measure the amp draw running? Not critical, just curious.
Based on the design and construction I believe it is an older unit, but I guess that's why it's so cheap. Thanks for the tip, I'll keep an eye for food leaks but Im planning to keep everything in individual containers. What is under the access panel? Perhaps I could tape up the joints.
The latches that hold the lid closed are bit weak if you get inexperienced people trying to close the lid with them in the way. They break but only cost $12 from the camping store.
For $400 odd dollars its still a bargain. I think they may have been more than double that a few years back.
Does this one need a separate 12/24v power supply for use in the house, or can you plug it straight into the wall?
They work a lot better with the factory cover and it keeps them looking good if you ever want to sell.
Good info. I'm just kind of curious mainly because I have 2 fridges, 1 draws 2.7 amps (on 12 v) when running and the other draws 5 amps. Duty cycle is about 1/3. Just wondering what the range is out there, and the Amazon add said something about 7 amps.
Ive seen some billet latches and hinges on eBay from an Australian seller, I assumed these were a weak point. If they break I'll try those.
My unit is the CF-80US which came with 12V and 110V USA plugs.
Although the source distribution center is only 45mi from me, the cooler arrived with slight cosmetic damage to the corner from being dropped. The plastic has a stress mark and a slight bend in the metal. I ended up getting the unit well under $400 and with an Amazon gift card it was closer to mid $200s for me. At this point I dont care what happens to it cosmetically and Im not going to sell it. Thanks for all the tips.
Just FYI, the DanFoss/Secop compressors (probably as well as most others) can be clocked from 2000 rpm to 3500 rpm. It's a balance between performance and efficiency. Some of the Domestic fridges have a "Turbo" button that temporarily kicks up the compressor from 2500 up to 3500rpm until it reaches it's desired temperature. Great feature!Good info. I'm just kind of curious mainly because I have 2 fridges, 1 draws 2.7 amps (on 12 v) when running and the other draws 5 amps. Duty cycle is about 1/3. Just wondering what the range is out there, and the Amazon add said something about 7 amps.
