Don’t they lifetime fill closed bearings?
I replaced hubs when I did my front brakes around 210k miles. Since it uses the same parts as tundra Front hubs there is a thriving and pretty inexpensive aftermarket. It’s four more bolts per side plus the axle nutDon’t they lifetime fill closed bearings?
A lot of people,even shops overlook this due to inexperience or laziness. I do stock pads and rotors since rotors are so cheap. I usually just clean the springs and pins (wet & dry sandpaper the pins) and call it good...Grab a tube of caliper lube. I like the permatex stuff.
I guess I'm curious where you are applying said lube. These are not floating calipers, so no pins to slide on. Correct? What am I missing?
When I did mine a few weeks ago there were pins front and back. Small unthreaded pins in front and large threaded pins in back. Since the PO only drove it 3k a year in a cold state, the pins ended up getting really stuck and I broke one in the front and stripped one in the back, so make sure you lubricate them at the very least. I had to use a special socket for stripped nuts to get the rear pin out and had to use a punch to get the broken front pin out.
Gotcha. I misunderstood what you said and thought you said no pins.The front "pins" are just there to hold the pads in the calipers, they don't move once installed. They should get anti-sieze on them.
REAR brake calipers are floating, so they need to slide on pins as the pads wear. Yup, they should get greased. I use good 'ol Syl-Glyde.
Those front pins look bone dry and caked with mud/crud to me. Some Kroil, a wire brush, and maybe a little bit of heat, they probably would have slid right out. Tapping on the inside end with a brass drift also really helps, just be careful not to mushroom the ends.
Per the Toyota service manual also should replace the bolts that hold the calipers on. I had my parts department look them up. I just did my front and rear pads bolts and rotors this winter. Used OEM rotors and the stop tech pads below are the front (came with pins and springs) since I tow a lot and wanted longer wear and more bite.Rotors ; need part #
padsTR09-0C111 (TRD)
Pins : 90240-06024
Springs : 04947-60149
2014 LX 570
Front only , can you please give me OK ?
