200 Series Brake Job - Part Numbers, Torque and How-To
I would recommend a full brake fluid replace at least every 100K miles. If you tow a lot or live in an extremely humid climate you might want to do this more often than 100k.
This. For sure. I don't drive as much as some, but I change mine every 2-3 years regardless of mileage. It's humid around me often.
Added to the FAQ
I use DBA Pads and Rotors. Nothing wrong with stock, just what I prefer
  • DBA DB1857XP Rear Brake Pads
  • DBA DB1838XP Front Brake Pads
  • DBA 42722S Front T-Slot T3 4000 Series Rotor
  • DBA 42723S Rear T-Slot T3 4000 Series Rotor
Thank you for this thread. I drive a ton - 21k since I bought my ‘15 200 since May 2024 - and expect to start towing in the future. I was planning on starting the brake upgrade research this spring. I am also working through the ‘new to me’ list and planning on doing a leveling and suspension refresh when doing the brakes - and adding the complete brake fluid flush to the list.
This has been a topic of conversation in the part number request thread, so I figured I would start one dedicated to 2013-2016+ 200s, but we can certainly add 08-11 and turn this into a mega thread.
I have a 13 and and 16 that will be getting new pads (also new rotors on the 2016). Below is a list of part numbers and torque values compiled from the other thread. Thanks to @Sandroad, @OGBeno and @bloc for this data. Notify me of any misinformation and I will get the thread updated. There are some redundancies in p/ns since only the front rotor changed with the 2016+. Note the torque value differences between the 2013 and 2016+.
Please add any tips, tricks, guides (youtube or otherwise) or personal SOPs to this thread!
The question I have at this point is, does the banjo hardware need to be messed with at all and can the brake/rotor job be done without disconnecting the caliper? Is there fluid loss if you separate the line from the caliper?
TRD High Performance Brake Pads (all years):
PTR09-0C111 - (Front)
PTR09-0C110 - (Rear)
2013 Brake Component Park Numbers:
04465-60280 - Disc Brake Pad Set (Front)
04466-60160 - Disc Brake Pad Set (Rear)
43512-60180 - Disc Brake Rotor (Front) Different from 2016+
42431-60290 - Disc Brake Rotor (Rear)
04945-60080 - SHIM KIT, ANTI SQUEAL (FRONT)
04946-60120 - SHIM KIT, ANTI SQUEAL (REAR)
90240-06024 - PIN, WITH HOLE(FOR FRONT DISC BRAKE ANTI-RATTLE)
47715-43010 - Disc Brake Caliper Pin (Rear)
04947-60140 - Disc Brake Anti-Rattle Clip Set (Front)
04948-60040 - Disc Brake Anti-Rattle Clip Set (Rear)
2013 Torque Values:
Front caliper bolt. 73 ft lbs
Hose to caliper banjo. 22 ft lbs
Rear caliper bolt. 65 ft lbs
Caliper bracket bolt. 70 ft lbs
Lug nuts, all models 97 ft/lbs.
2016 Brake Component Part Numbers:
43512-60210 - Disc Brake Rotor (Front)
2016 Torque Values:
Front caliper bolt. 133 ft lbs
Rear caliper bracket bolt. 114 ft lbs
Rear slide pin. 65 ft lbs
Hose to caliper banjo. 22 ft lbs.
Miscellaneous Small Parts:
91672-L1240 - Caliper Bolt
47449-30030 - Shoe Hold Down Spring Cup (I ended up stripping one of these because I had the parking brake engaged when pulling the rear rotor.)
Video Assets (currently unvetted)
Australian Images Walk-Through (Includes Hand Brake shoe replacement)
Jaffa Adventures Walk-Through
Did the 2016 rear brakes parts change to larger bolts as well? Why are the torque values so much different from 2013 to 2016 on the rear? The terminology between the 2013 and 2016 examples doesn't exactly line up, but it looks like just 1 rear value changed if you move some stuff around.
On 2016 you call out the rear slide pin to be 65 ft lbs and on the 2013 you have the rear caliper bolt as 65 ft lbs. Guessing these are actually the same bolt and should both be the slide pin bolt.
Then for the 2016 you have the rear caliper bolt listed as 114 verses the caliper bracket bolt at 70 ft lbs on the 2013.
Good question.
I only had to remove the caliber bolts to get the new pads in. I did not need to remove the slide pin/bolt.
The torque did go up quite a bit in the 2016, but I believe it’s the same bolt for all years. I think the FSM says these are one use, but I reused them this time. I did have to buy a new torque wrench to achieve the prescribed torque on the 2016 front caliper bolt. Always like an excuse to buy a new tool.
Thread bump to say just got everything here for rotors, pads, pins/fit kits, front and rear for $457 shipped to my door from Fred Anderson Toyota (Raleigh NC) under the 25% off + free shipping sale. Appreciate this thread compiling the OEM part numbers!
I just had to replace my front slotted dba rotors after only 20k miles. They somehow got warped during a recent trip to the high country, and I don’t know why. Seemed awfully early for them to go bad. No towing or super aggressive driving involved. DBA 4000 t3 series if I remember correctly. I’m wondering if anyone else has had the same experience. My mechanic, who also owns an LC, told me even though they are heavy vehicles, 20k miles was a bit early. He also said the rotors were not turntable due to surface hardening only, so he installed regular stock rotors. Maybe I just got a improperly heat treated set of rotors from DBA?
Could having heavier and bigger tires ion the vehicle be part of the cause?
The DBA rotors ARE able to be machined. They are NOT surface hardened, the entire chunk is heat treated for internal stresses.
$500 worth of rotors pissed away. Any chance your mechanic has a nice set of DBA rotors on his cruiser now….?
