drive my '64 every day, to work and around town.. not to far out of town View attachment 2019099as it tops out around 50 mph.
So basically functionality,comfort,safety,convenience,
reliability,.....vs.....strong ,dependable ,and cool as hell......Im leaning toward the daily 40 .adventures are good...maybe not at the moment but a few years later they make good stories.plus I’m not rich enough to buy the car I want![]()
When I bought my FJ40 it was my daily driver and only car to get around in. I am from Wyoming and our winters can cold sub 0 but keeping warm was not a problem before I rolled it and not bad after either. Mine has the cold weather package.Wipers that’s definitely something to think about ... winter? What are some of the issues of driving in winter ?This is my first land cruiser,but not my first s***y Toyota ..looking at the heating system , it doesn’t seem like it would do that great a job heating my cab and the lack of air tightness would let whatever heat escape...
I kept mine tuned up all the time but waited over 40K to adjust the valves the first time.I daily drive my 73 with AC, 5 speed, 3FE, front disc brakes and power steering, 32" tires, It'll go 70-75 no problem. 80 is my limit, the tops of the doors start to peel out about there. Carb and points start to take away reliability unless you know how to take care of them (I found I did not).
mine didnt know the difference and sometimes they fell off the seats when Mom drove the speed bumps in the trailer court.Cloth. I knew you had an ace up your sleeve. I’m with you though, there are very few things that smell better than old vinyl. When I was 16, my first car was a ‘69 VW. It was completely original; down to the seats (yet I don’t remember the heat). Every time I step into the 40 now, it reminds me of being 16. Wouldn’t trade the smell at all in the 40. But then again, I’m not daily driving the 40 either. Guess I can’t have both a cool smell and a dry back.
Exactly. My kids get along great with each other, but force them to face one another on a daily basis and you’re asking for trouble. That’s just torture.
did not exist when I was driving mine all the time.I like it ...couple bottles of rain ex in the glovebox good to go,
Sounds like winter and spring driving in Wyoming. I didn't do much 4 wheeling in the spring because the ground was just too soft and still some snow in the gully's that you would get high centered in if you did not put your foot in it to carry you to the other side.Yeah, I've got a bit of winter driving experience.Montana doesn't like to use salt. Sometimes they don't like to plow either. The roads develop a base of packed snow which is pretty good to drive on if you have good tires. Good tires means soft rubber with sipping, plenty of tread left, and possibly studs. Studs are definitely nice, but something like the Bridgestone Blizzak works well without them. As the weather turns toward spring that base pack started to break up. You end up with "potholes" in the snow pack, which tend to be hiding potholes under the snowpack. In short, the roads get really rough. This is a situation that does not favor a short wheelbase. The shorter the wheelbase, the less deviation from straight ahead is required to start moving the vehicle left or right.
Example: It's late winter and you're driving the 40. You come up to an intersection in town that has a stop light. Your light is green and you're going straight, so you maintain speed. Lets call it 25 mph. The areas where cars generally stop for a red light have broken snowpack. You hit that broken, bumpy, mess of snow at 25 mph just before going into the intersection. The front end bounces right just a bit. You correct left just a bit. You hit another bump and the front end bounces just a bit left but you're already correcting left. The short wheelbase causes the truck to veer pretty significantly into the oncoming traffic. You now have to make a big correction right. Maybe you jab the brakes somewhere in the mix? Well, now the front brakes are locked up. Are you in 4WD? You're going to need to tap the gas to get the wheels spinning again so you can steer.
In Michigan they use TONS of salt so it's a different set of issues in the winter. The roads are either covered in snow because the plows haven't been through yet, absolutely clear, or slushy and icy because it's too cold for the salt to work. Studded tires are illegal in Michigan too. I liked to run really narrow tires in the winter in Michigan. My theory was that the narrow tires could cut through the slush better. They still needed to be soft rubber, sipped, and with plenty of tread on them.
To make a wall of text into a short statement. I don't drive my 40 very much in the winter. If I do drive it, I generally don't drive it to town.
