Very nicely done...
Holy Crap dude, I bet you were nervous cutting up that fender!!!
Curious, do you think a 3" snorkel pipe would fit INSIDE the fender, pretty much following your route and then pop out near the wind shield?
To answer the above question, yes, it will. I sat a section of 3in tube in the guard to see. Yes it will fit but it would most likely have to sit where I've positioned it which is just before the guard steps in towards the panel. Definitely doable but would be incredibly time consuming working out a way to get it on and off without removing the guard each time.
Ali,
I can see where getting the 3" pipe inside the fender would work if you have a big slot cut in the fender. Won't the whole fender have to removed to get it inside if the slot is not there?
Found this thread while looking for airbox ideas.
Have you had any bad experiences with the diagonally mounted filter? Not sealing or so?
I might steal your idea
I've angled it for several reasons; 1) to reduce the final width of the box, 2) eliminate any more bends than needed getting air into or out of the air box. In this case, the snorkel feeds in from the left, and the turbo sucks it through from the other side (underside) on the right.
Next installment will be mounting it in the engine bay and making the inlet and outlets. TBC...
