Thanks. You’re not running a body lift like he will be though, are you?First is in LOW, rest are HIGH. I have Slee sliders. Next: resonator delete
Not yet;Thanks. You’re not running a body lift like he will be though, are you?
Mine spare carrier came with 3 lug-nuts. They all fit nicely, no issues lining up.I've reach out to Dissent already, but anyone have issues with the tire carrier lug pattern not lining up?
With a stock wheel and lug nuts I can get 2 lug nuts on. With aftermarket wheels and extended shank Gorilla lug nuts I can only get one lug nut on. The studs are just off by a 1-2mm, not much but enough where if I force the lug nuts it'll damage the wheels or lug nuts.
I do not have this issue and I’m using the lugs for my Icon wheels.I've reach out to Dissent already, but anyone have issues with the tire carrier lug pattern not lining up?
With a stock wheel and lug nuts I can get 2 lug nuts on. With aftermarket wheels and extended shank Gorilla lug nuts I can only get one lug nut on. The studs are just off by a 1-2mm, not much but enough where if I force the lug nuts it'll damage the wheels or lug nuts. And I did this with just the tire carrier off the arm to make it easier to manipulate.
