So, was camping in Pismo this weekend for Surf 'n Turf. Got packed up Sunday morning and truck wouldn't start. Symptoms of a drained battery. Jumped it from another 80, and it started up first time. Scangauge showed voltage around 15 once it started as it tried to recharge the battery, and then settle in the normal mid to high 13 range. Let it idle for about a half hour, and then drove for about an hour. Stopped twice (once for gas, once for lunch). Started back up no problem each time and then drove straight home for about four hours. No issues. On Monday, started right up in the morning, but was a little weak in the evening, but it started and drove home with no issue. But then it started being an issue.
Yesterday (Tuesday), it wouldn't start in the morning (dome lights and dash lights were dim, and didn't have enough juice to attempt to crank). Grabbed a battery on the way home to drop in, but then I started wondering if maybe there was an issue with charging system or maybe a parasitic drain that might be draining the battery. I didn't want to drop in the new battery until I was sure it was just the battery. On the existing battery, I took a reading on the battery posts with the mulitmeter, and it registered around 8.2, which would explain why it wouldn't start. I jumped the old battery in the truck (again, turned first crank on the jump) and drove over to the local parts store that does free tests on batteries and charging systems. I had them run tests on the battery and charging system. They said the battery was fine, but there was a problem with the charging system (guy was saying it seemed to him like a bad rectifier in the alternator). Something didn't quite make sense. Drove it home and broke out the multimeter to get some quick readings. With it still running in the driveway, scangauge was reading voltage of 13.7 and I was getting a reading on the battery posts of 13.6 (so, fairly close readings). Turned off the ignition, and it was reading 12.6 on the posts. So that seemed okay.
Fast forward to this morning, grabbed the multimeter to get a reading before I even attempted to start it, and it was at 8.4, so something definitely isn't right.
So, after that short novel, I am looking at the following conclusions:
Thanks.
- The charging system might be okay after all (I don't see how a bad alternator can be charging the battery when the engine is running since it runs fine once I jump it, and then is draining the battery once the engine is off).
- Battery is toast and won't hold a charge, despite the diagnosis of the parts store guy's test (this would be the easiest fix, and I plan to replace with the new one, but I don't want to ruin the new battery if there is another problem elsewhere)
- There is some kind of major parasitic drain that has just come up that is putting a pretty major drain on the battery (taking it from 12.6 to 8.4 in a matter of about 9 hours of sitting seems pretty extreme)
Thanks.
