BeerM3
Okay, I'm in need of help. After 2 months of monkeying with the brake system on my 1/76 I think I finally figured out what I did wrong and I'm hoping someone here can confirm.
Nobody in their right mind would get rid of a front disc axle and replace it with drum, but that's what the PO did and at the time I was too naive about FJ40 year differences to know that a 1/76 should've had disc, proportioning valve, etc. In fact the bracket that held the proportioning valve is still there. After a few months of tooling around town with decent brakes it started to get mushy and I determined the MC needed to be changed out, which was correct.
Here is what I started with.
And it was definitely starting to go south
So two months later with a new drum booster from CityRacer, MC from Napa, all soft lines replaced with OEM, rear wheel cylinders replaced with new from CruiserOutfitters, and too much DOT 3 I still wasn't getting a good pedal. Bleeding was done methodically per Coolerman's tutorial. After more frustration I discovered one of the front cylinders was frozen shut, so that wheel got two new cylinders from Napa.
Before someone jumps my case about replacing all cylinders per axle at the same time; you're right. But I have a salvaged '76 front axle that will be rebuilt in the next year or two so right now I just need to get by. The front driver's side cylinders were replaced fairly recently by the PO.
