Disabling the AHC and AVS systems, no warning lights. (4 Viewers)
Won't I have to switch to tundra calipers/disks to use tundra lines? I'm not against that.
If anyone is curious, with tundra components and 3.0 king shocks, I gained 3" of droop and have a total of 12" of travel in the front.
StopTech has extended braided steal lines IIRC
As it's a CANbus architecture, there's a module somewhere simply relaying that information about the missing module it's expecting (maybe the instrument cluster module?) The PCM's (engine and trans) are likely the same between the LX/LC/Tundra 5.7 just from a parts production perspective.
Are the different computer modules amongst the systems the same between the LC and LX except for where the AHC stuff is concerned? If the other modules in the car share the same part numbers between LX and LC, new opportunities abound. New dash module that is a LC so it's programmed to be ignorant of the AHC ?
I think I need to lower this a couple inches. :)
I only backed it out of the garage, I need to install the rear stuff now.
No warning lights :p
I wasn't planning on removing all the suspension components under the rockers, but looks like I'm going to have to. That's where king wants me to install the reservoirs.
Is there a market for these used, but working components?
I'm sure someone will want to buy my oem tundra upper arms with sensor brackets welded on.
Yeah there is a used Market for the ahc accumulators and solenoids. Shocks too.
I can’t wait to see pictures of the complete install!
Where are you located? I’m interested in all four shocks.
I'm in Las Vegas.
I need to figure out what to do with this. The reservoir elbow is binding witht the coil bucket. I already ground out some of the coil bucket and removed some material from the elbow.
From the pictures I have seen of the Tundra, their coil bucket is smaller than the 200. I guess I'll grind more out of the coil bucket.
Maybe cut this shape out and weld in a section of a tube.🤷‍♂️
@turbo8 Do you have one of the front OEM struts disassembled?
Need some measurements of the factory front coil spring.
Free height -
Top of coil inside/outside diameter -
Bottom of coil inside/outside diameter -
Exploring aftermarket spring options for my LX570 while retaining AHC.
Thank you
