curious1 said:Not legal.
curious1 said:I would agree that if a referree looks at your plans and says o.k. go with it. At the same time you have to be very careful. Follow this bad scenerio.
A cruiser owner goes to a referree and or CARB and asks if it would be legal to swap in a toyota diesel engine. They say yes. The owner installs the diesel and takes it to the referee only to be told it is not legal and the car gets black listed until the original motor is installed. The reason given is that now that they look at it they realize that the exact diesel motor that was installed was was never available in the USA. Therefore not legal. The CARB and referee never imagined that someone would import a non USA motor for install.
Yes there are instances of people that know someone who knows someone that have done all kinds of installs. There are lots of diesels that have been installed and have made it through the system in some way or another. Most people will do there homework and are willing to take a chance that they may run into a problem.
The CARB requires the following for a diesel swap to be legal.
The donor motor needs to be from the same weight class as recipient vehicle. A heavy duty drivetrain can't be installed in a vehicle rated as light weight.
You can not use an industrial diesel engine. i.e. out of a fork lift
The diesel engine needs to be the same year or newer than the recipient vehicle.
The diesel engine needs to have been available in the USA from the dealer.
FYI... The DMV does not issue new VIN's on diesel conversions. They only change the motive power on the registration from gas to diesel. This is first hand knowledge from three conversions.
The 300TD would work as long as it follows guidelines for year and was it available in CA.
People have tried, but I have not heard of a Benz. conversion that actually was finished. There are some issues. No adapter. There is a problem with balancing a Benz motor to a different tranny. You could do the following. Run a divorced transfercase and keep the benz tranny. Make the car a two wheel drive with the benz tranny. I don't really like either.
The 80 is not residing in California.
Aseif007 said:I also know of somebody in Palo Alto who dropped a UPS diesel in his FJ-60 last year legally using the referee method. Just what I have heard......
daddyo said:Does anyone know the rules for diesel swaps in California?
Can I do a Cummins 4BTA swap and be legal here in California?
Thanks for your help.
Andrew
fe sus said:I don't know for sure, but here in WA that would only be okay if the rig was older than 25 yrs. In general, CA seems to have generally stricter emissions laws... not to say people don't do all kinds of swaps and never have any trouble... here in WA, the law says that vehicles must have an engine installed that was an option for the vehicle when it came from the factory, regardless of in what country. This is why swapping a 3-B into an FJ60 is legal... here in WA in any case.
PVCruiser said:Yes you can. Regardless of what other people on this board say, you can. All you need to do is fill out one form at the DMV. I forget which one it is....
ChuckB said:So, what you're saying is that all of your troopys are legally registered in CA and once registered are smog exempt? If that's the case then I may be paying you a visit and coming with some $$$$
PVCruiser said:Yes. All of my rigs are legally registered in CA. I plan to stay in business for while... Cutting corners would only catch up with me.
tlcruiserman said:If you have a swap done in another state, any state it the union (of the USA) and that is titled and registered as a diesel, they you can legally title and register it in California. The exclustions to this would be if it is a new model year and has less than 700 miles on it.
