Update: Ok, so here is an interesting observation. The Cruiser ran beautifully for nearly 2 weeks, no smoke - ever - even at ~0 degrees C on cold startup. One nice afternoon I was doing some stuff (not engine or fuel system related) and added the usual amount of
Diesel Fuel Supplement | Canadian Tire to the fuel tank.
The next evening I started her up, and wow - the crappy white/blue/grey smoke was back, just as bad as before. I then immediately took her to the local Co-Op gas station and filled with diesel to help flush out the concentration of fuel additive in hopes this would clear it up. So far no change, but I've only put 200km on since it started having an issue again. If not adding the fuel additive clears up the smoke, then I won't be adding it again. Especially since the results from
http://www.johnfjensen.com/Diesel_fuel_additive_test.pdf show that 2% bio diesel had the best performance of lubrication over all other lubricants, and I believe Canada has at minimum 2% bio diesel in all fuel suppliers? (pls correct me if I am wrong)
