sounds perfectly normal to me - just a beautiful 1HD-T purring! smokes a little bit more than mine (and the engine is cold) but unless the oil consumption is unusual or it smokes like that when warm I wouldn't worry.
pm me if you want brand new oem injectors.
You wont be looking anywhere close to $3000 i dont know where you guys even get prices like this.
I can get you new injectors for 180-205ea without any core charge.
Uses less than 1L of oil ~10,000 km
The smoke smells like diesel. Injectors are next on the list.
I see you have removed the acsd.The whole purpose of this device is to clean up the emissions when cold.
It advances the timing a little until the engine warms up,didnt anyone tell you this?
Yup, but my problem continues after it's warm.
3 times since I bought the truck it would not start when cranking over. Cranking power was good, it really tried... but would not start until I used the "manual" IP pump and gave it 3 or 4 good pumps. One time this happened the truck sat for a week, the other time it only sat overnight.
Hi Rosco,
Thanks for the help. It gets way better when the engine is warm, and the warmer ambient temp seems to make it better as well.
It hasn't done the starting issue now for many months. It turns over really quickly.
This isnt so unusal then. Have the glow plugs been checked? Direct injection engines dont need much glowing but diesel being sprayed onto warm glow plugs does wonders for complete combustion.
Your ACSD removal is probably a contributing cause
I am thinking your injection timing is off along with injectors
My injection timing is off since my ACSD removal
Hi asutherland, so what did you find/ whats the real cause of your 1hdt smoking, is it the glow plugs or injectors??
Since I made no changes during our trip, other than where I fueled up, I can attribute the no smoke to one (or more) of 3 things...
1. Winter diesel sold in the colder towns.
2. Higher grade diesel sold at stations I don't usually frequent, Husky and Shell
3. High speed/working harder for many hours at a time have "blasted out" the crud.
