I searched the site and didn't find my answer.
1979 desmogged 2F
It will accelerate with a slow appication of gas pedal but when I stomp on it, it dies.
Here is what I know:
replaced accel pump when it wouldn't start,
replaced idle solenoid when it wouldn't idle
set mixture screw to steady 21" vacuum
wires, plugs, coil all good.
Here is what I can't figure:
I opened the window and marked the needle with welders soap,
I pulled the cover underneath and marked the BB, there are no other marks on the flywheel.
with the timing light, I can't see the BB when it is idleing, I advanced the timing by lifting the throttle and still no BB
I loosened the clamp holding the Distributor but it won't move.
What is the secret to getting the distributor loose? with the heater hoses, dipstick, oil filter and battery tray, I can't get to it.
I think I need to retard the timing, so which direction do I turn it to retard?
Am I doing the right thing to correct the hesitation?
1979 desmogged 2F
