destins 1964 fj40 FST restore thread (9 Viewers)
Michael,
the needle "jump" always only a little in the + section ;)
Cheers
Peter
Yes but with the battery not completely charged it should read higher on a pre '79.
does any one have an intact fuse cover with the sticker paper inside saying what is what?
Just curious how hard they are to come by :)
Mine currently has no cover ;)
photos would be awesome, saw a 25 cover below, but mine is a 40 ;)
And the amperage is dif, as well as fuse amounts ( mine has 5 fuses // 30-30-5-15-15 // )
attachment.php
so found out some good news :)
I went down to the ABE battery electrical shop to buy a fusible link, new power cable and ground cables for the rig, and I explained how i thought my generator and voltage regulator was not putting out the proper volts at idle.
Dude took a look at the generator and said that it was rebuilt with a 6 volt armature and brushes!
Thats why it was not getting 14v at idle doh!
I am gonna bring it in and they can swap it to 12 volt for 80 bucks :)
saweeett!
Oh and the neighbor was moving and had an awesome rig posting photos soon!
attachment.php
Yes, but at my shop. I'll get you some photos when I get over there next (too cold to be wrenching on the mercedes project).
Mine has it in english, and when you hold the paper up to the light, you can see the paper with the japanese writing under it. Pretty cool.
Awesome man!
Stoked to check it out :D
Generator will not bring 14V at idlle, you need more revs or change to alternator.
damn really?
The old dude at the electric shop seemed damn certain he could get it running that way, he said he just got an old truck running up at 14v at idle with a proper generator brushes etc...
At the very least i should have a generator with the correct 12 volt brushes and armature correct?
Going to clean up the light switch connections next, then clean my fuse box connections to seee if i can reduce the resistance in my wiring :)
Also plan to run through and make sure all my grounds are solid.
Destin, consider adding a little dielectric grease to your connections after you clean them up. It keeps water and corrosion out.
Amazon.com: Permatex 22058 Dielectric Tune-up Grease - 3 oz.: Automotive@@AMEPARAM@@http://ecx.images-amazon.com/images/I/51w0RmT93AL.@@AMEPARAM@@51w0RmT93AL
**** really?
The old dude at the electric shop seemed **** certain he could get it running that way, he said he just got an old truck running up at 14v at idle with a proper generator brushes etc...
I'm not saying your doing wrong on this, just that a gen. needs 1000 to 1500 revs to deliver 14V. Just don't want you to think something is wrong when the work is done and it at 12V when idlle.:)
