- Thread starter
- #2,461
Pull the rotor and look inside it. You will see a plastic "key" molded in it where it fits onto the notch of the distributor shaft. Depending on the rotor that key can vary from sloppy, to tight ............... as you just described, to just won't fit down on the shaft.
Yes, the voltage reading was probably correct, but totally useless. I'm not going to try to explain why, let's leave it at you had it hooked up wrong. The voltage should be at least battery voltage between the + side of the coil and ground. So take one lead of the voltmeter and attach it to the + side of the coil and take the other lead and attach it to ground. You should see around 12V if the ignition is on and the battery just started the truck.
If you are running a generator it will not be much above battery voltage until well off idle, this is the nature of the beast and one of the reasons why generators were replaced by alternators.
Test this stuff and put your voltage worries to bed.![]()
Thanks man
Sorted out I was hooking up the volt meter incorrectly, it is putting out 13.1 at idle which seems good.
Thinking maybe vacuum leak at the carb that does not seal until it heats up?
Will see if i can reproduce this tomorrow and go from there
