Guide studs only on the early F's
it's threaded but only for guide. there is no nut on the end to tighten.
someone must have replaced the stud at one time. it's only long enough to be flush with the intake.
as much as intake exhausts are a pita i don't think it's a big deal to put in a longer stud so you can tighten it down.
Just remember that mine is an F120. Maybe you guys with that extra 15hp need those studs to keep the manifolds from blowing off the head.
hmmm
mine do not extend past the manifold mounts, the studs that is.
However, if it is better to get longer ones and torque them down now would be the time to do it...
Let me know guys!
Thanks
Idave, do you happen to have photos of your intake studs for peeps to see?
So, you guys with the short studshhmm
: are the outside ends threaded like the figure shows? That picture comes from an engine manual dated 9/66, and everything in it matches my engine manufactured 9/64, except, maybe, this.
The short studs / dowels are threaded also. They just don't extend past the manifold.Only thing I can figure is that they must have had a reason for not anchoring it there (possibly stress during expansion/contraction). The manifolds are pretty active when heating / cooling. In the same vein.......you need the intake manifold rings or you will be fighting an intake manifold leak there eventually.
What would be cool would be videos of certain steps in the process...sort of like all the decent engine building videos on you tube...it would also be a great help for future F135 newbies![]()
Spoke with one of the main machinist/rebuilder dudes, he said he has prolly rebuilt 100's of old f motors![]()
update
Motor is at PER being rebuilt
They said i could drop by periodically to take some photos etc![]()
The place is like 7 blocks form my house![]()
...every old machinist will say that. . . .because I think the "F" in his sentence means f#$%in he he he
...at least that was the case with the engine builder back home in Montana.
