after the paint is finished, final coat etc...
Is it smart to "bake" it to cure it?
I remember shane saying he backed his jack after painting for an hour at 150 degrees...
I know for CERTAIN, my wife will not let me put it in the wolf range haha!
What are my options?
Ideas?
not necessary ...
...never "baked" parts when I sprayed them with a can.
Cheers
Peter
diagramit is for a 1969 ...but...better than not
also....nice painting job ...looks great
Check the paint with a finger nail in a few days, let me know.
I sweat them first, and yes (sorry Destin) it's a must with the tinted yellow Krylon paint. I have a company that "Bakes" the plastic tops and registers that they paint with a two part epoxy. Similar to powder coating but at a lower temp with plastics.
If you use a torch, you can sweat the metal and watch the moisture line walk away as you move across the metal. This insures for a good bond to primer and primer to paint. As this is not a misting or light amount to get a proper coverage as the paint will run off the peaks of the casting. You will need it to cure and be able to hold several coats to get that powder coated look and even coverage.
I have painted a few over the years.
hmm should i restrip and paint it then?
Or just get a cheap toaster oven and bake the jack?
I think mine is an oder jack, did not see any plastic![]()
or i could just powder coat the damn thing.
Just toss it in on a cookie sheet at lowest setting with door cracked open for 20 minutes. Can't get much over 120 so keep the door open to compensate.
The plastic I was referencing for baking was for the heaters in the 74-84 plastic tops that have a two part epoxy that has to be baked to cure.
Can't powder coat it, the grease will come out and kill it.
nice
So about 120 for a bit will effectively harden the krylon rattle can paint yeah?
Thanks man![]()
"tinted yellow Krylon paint"
what kind of paint is that?
never heard about it.
Think Toyota never used such a paint.
If you do a normal paint shop
the steps will be:
a) clean the part
b) remove rust / sand it
c) clean it again
d) spray primer
e) sand it again (finer sandpaper)
f) clean it again
f) spray the top coat
Cheers
Peter
Guys it`s a truck only a truck
don`t pamper it please![]()
forgottenAllan, It's a Jack.
Cheers,
Shane
forgotten
yes it`s a jack but it`s a tool only a tool
guys do what you want
but
I never, never bake (baked) my tools not in the past and not in the future
Cheers
Peter
Not to "Jack" Destin's thread any more, but it really does make a difference if the finer things that get paint. Mostly on cast parts from motor mounts, jacks, alt mounts and so on.
Allan, I would not jack you.
destin, did you paint the threads of the screw part on top too?
the steps will be:
a) clean the part
c) clean it again
d) spray primer
f) clean it again
Cheers
Peter
