I had the serp belt replaced along with timing belt -- but not the fan pulley -- which is what seized.
You mean fan bracket?
I assume yellow paint is tech marking bad spots he found on timing belt, to highlight?
Waiting to hear why mechanic looked into T-belt area???
____________________
I can think of only two reason a mechanic would pull timing cover, while R&R a serp belt.
1) Serpentine belt broke wrapping around pulley, damaging the timing cover. So t-belt cover was removed to repair or replace damage. We've seen a case in mud, where a serp belt actually did this and took out the timing belt..
2) After replacing serp belt. Mechanic heard something concerning and investigated with serp belt off, still hearing, he pulled t-belt cover.
I can think of 5 possible cause a belt would have a rip like this:
1) During install tech pried on belt to get belt onto pulleys or sprockets. Prying, twisting or bending timing belt should never be done.
2) Belt was defective or damage in shipping.
3) Small plastic cover left off, an something got into belt area.
4) Counterfeit.
5) Serp belt damage the timing belt.
I've returned 4 timing belt kits in last 6 months. Due to shipping damage to parts in side. The water pump and pulleys rip around in the box, during shipping. I've not seen a belt damaged. But have seen damage water pump and it's gasket twice for each. The belt is on side of box with pulleys. I suppose shipping damage is in realm of possibilities.
Not likely sabotage!
