It finally came! Here is cell phone shot of it. Won't know the fitment until late tonight!
Thanks for you're patience guys!
What have you decided about formats? Generic + filler plates maybe???![]()
I wonder if you could incorprate one of these into one style?
Amazon.com: Digital temperature meter with remote temp sensor: Everything Else
You asked for feedback:
1. Why such thick material?
2. Still more interested in a generic main piece with modules that can be screwed on with various switch blanks
What's your reason for wanting 1/8" panel?
...just wanting one with the heater controls cut out.
Looks...
Not exactly... see post# 81.
I would like a main panel with large "blank" holes. Then also make thin panels that have the cut-outs for switches (stock or carling), and also blanks. Those can be screwed onto the main panel (from the front or behind)
I'd like the space where the ash try and cubby are to he solid. I'd use that location for locker switches, usb plugs, gauges, etc.
The only issue I see right now with 1/8" panel is in trying to keep the recessed oem screw look would obviously have the stock screws heads stick out. But I'm sure if you wanted to, you could find some taper head ones to set flush
