Cruiser Patch 100 Series Products Thread
Restock update:
Brass heater tees back in stock
Drain plug kits back in stock
Crush washer kits back in stock
Prius rear wiper kits back in stock
CV boot clamps back in stock
Front diff bushing kits back in stock
Engine mount kits back in stock
Heater tee delete kits back in stock
Axle snap ring kits back in stock
So many more... CruiserPatch.com
70/100 Fender side marker light kits
Panhard rod poly bushing kits in stock
Starter motor kits coming back soon
TRD shift knobs coming back soon
YOTAMD 'Cruiser Patch' branded key fobs coming back soon
We're working on adding some easy-to-navigate spring lists grouped by series fitment and recommended weight/load.
Ideally I would love to include details about each spring rate as can be compared to OME, Ironman, OEM, and many more. For now we only have listings for Dobinsons Spring & Suspension but given that their dual rate springs are one of the most comfortable options, we're proud to bring these and more options to CruiserPatch.com
100 Series Rear Springs (teal)
100 Series Rear Springs (black)
We're a licensed Dobinsons dealer now so if you ever need anything from them, reach out to myself or Knox Barber for sales and support 🍻
View attachment 3766995View attachment 3766996
We're a licensed Dobinsons dealer now so if you ever need anything from them, reach out to myself or @Fort Knox for sales and support 🍻
Um, not sure how much sales or support help I'll be.
Interested in a front wiper kit (w/ replaceable wiper insert, not the 1-piece arms my Lexus dealer sells) for sure!
Strangely hard to find correct PNs for that, lots of vendors only seem to have one side, there have been a bunch of superseded part numbers, etc.
I legit just pieced this together and received my order last week. If I had seen Patch working on this, I would have ordered from him and supported a good guy.
@cruiserpatch I am open to buying all future rubber wiper inserts with you going forward.
Here's the kit with the arms etc. for the front.
I do plan to add the inserts/refills soon as well since those are impossible to track down from dealers /no one behind the counter ever knows wtf I'm talking about...
out of stock right now but feel free to rip the PNs for the blade assy.
Who would be interested in aftermarket torsion bars that are of comparable thickness to OEM Land Cruiser bars?
I've been in communication with a manufacturer who can make custom size bars and would love to help provide more options for 100 Series owners looking for a lighter front spring.
Torsion bar spring rate is dependent on several factors but the most common delta variable is the bar thickness. See a list of measurements below:
OEM Land Cruiser (U.S. spec w/ 2UZ): 29-29.1mm
OEM AHC (U.S. spec w/ 2UZ): 25.3-25.4mm
Old Man Emu (OME): 30.5mm
TJM: 32mm
Sway-a-way: 32mm
Ironman4x4: 32.4mm
In my experience, the Ironman4x4 32mm bars are extremely stiff, allowing for virtually zero up-travel in low-speed scenarios for lifted, heavy-built 100 Series. I run OEM 29mm bars in my 1999 LX470 (non-AHC) which weighs roughly 6800-7200 lbs fully loaded.
Running a lighter spring means more pre-load is required on the bar to apply the same level of force to achieve the desired ride height. That makes the LCA reinforcement plates extremely important (as with high-spring rate bars like the 32mm Ironman).
If interest is high enough, I'll more than likely start a new thread specifically for these torsion bars.
I'd like to also gauge interest for AHC owners with extra weight who are looking for a 26-27mm bar.
Happy Holidays- Cruiser Patch will be closed 12/24-12/31 as I will be getting married on December 31st!
Our honeymoon will take place the first full week of January so orders placed between 1/4/25 and 1/12/25 may not ship until 1/13/25
Thank you for understanding 🍻 💒
I'll be listening to as much info an help as I can from TLCPNW and CruiserPatch and anyone else that wants to chime in. I figure I should make a quick build thread and get some part numbers and pics (because its worthless otherwise) Pic of the Truck in discussion. Only replaced some bits and added the tent since Purchase.
What about a vacuum line kit?
coming 2025. I’ve got part numbers for most of them but still working on fitment and years (like the PCV kits there are many)
I get at least one request for this per week so it’s pretty high on my priority list 🍻
TJM: 32mm
Sway-a-way: 32mm
Ironman4x4: 32.4mm
Congrats on the wedding and the honeymoon! Vintage LC driving somewhere?
Probably taking her 2002 Limited 4runner (the seat heaters are so nice).
My truck is currently parked at the shop for some much needed TLC
Yeah the seat heaters being hot is most important.
That looks like a lot of fun on your rebuild.
Btw thanks for shipping those to orders to Washington in like 12 hours total.
Thanks to @cruiserpatch for the excellent service and speedy delivery, even while preparing for his wedding.
His attention to service is leaps and bounds above the other vendors on here.
Cheers, bro!
I’m trying my best to keep up.
I’ve got over 30 orders to catch up on today. Taking next week off for the honeymoon. Will ship again on 1/13
