crankshaft pulley puller
Florida
What puller do y'all like for removing the crankshaft pulley/harmonic balancer?
I use a bar type puller, use the 2 threaded holes in the pulley for the bolts.
Like this
pic from @OSS is what I was referring to in my post. I use my 1/2' impact and that usually takes it right off.
the hard part is getting the crank nut off.
I used the crows foot one from advance auto. I rented it. But I went thru back and forth cuz the bolts weren’t the right length. It came w/ 2” or 4” but I bought 3” from a hardware store which was perfect.
I did tho purchase the above puller after the fact.
5’ length of pipe over your ratchet handle for the 54mm crank nut and hang on it over the passenger fender.
Do not use the type of puller that relies on jaws to grab the pulley from its edges. That type will damage the pulley by bending it as well as overstressing the rivets that attach the pulley to the harmonic balancer.
