That it's probably time for the "
Big Three Upgrade"
"He went on to say; good idea to check resistance of cable (off the vehicle), comparing to new cable. That if I see corrosion near lead, you can bet it's into/around wire strands and lead. This will increase resistance and must be replaced."
___________________________________________
Here's the full store:
This seem like a good thread to share something I just learned from a United Airline mechanic.
While on a flight to LA from Denver to buy The Black Knight (yes I name them) last week with my girlfriend, we got stuck in the very last row. She took window seat, while I the aisle thinking/hoping no one would take the center. Well, a guy 6'4" did, that couldn't get his knee to fit in, so I gave him my Knee space. We got to talking gear-head stuff the whole flight. He into diesel Mercedes and me into 100 series (what else). I gave you the above story, so you know where info comes from!
He told me in aircraft they have a tool that used to clean/grind under the ground/negative connection(s) on the air frame. They then add a dab of sealant to spot before bolting back on the the ground lead. They finish by cover assemble (Air frame, ground lead & bolt) with the sealant.
He said he's does same procedure on his car's. Cleans paint off from under leads on grounds and then seals. He's helped friends do the same, which cleared up electrical issues they had. He said the paint between lead & body metal increases resistance.
I asked "what is this sealant", he gave me a the name of this special aircraft sealant, but said I did not need it, that I could just use silicone sealant. That as bolt tightens, sealant squeeze out making a good contact and a perfect seal around the lead end.
