My driverside front bump stop appears to be contacting the front suspension spring with bigger bumps or bigger holes cycling the suspension. I hear a "spring" noise and now see a rub mark on the front of the front driver bump stop. Right where it goes from rubber to metal there is a rolled lip on the front bumps stop. I can see a rub mark where it is contacting the spring. That bump stop appears to not be centered well in the spring, a little off center.
A few months ago I was in a deep muddy field after spring thaw. Nothing around to winch off if I got stuck. I had to turn around to winch my buddy that was already stuck. Seeing as I was the only one not stuck no way was I going to stop and loose momentum while turning in a large circle. So as you can imagine it became a 4wd donut. When I left the field onto the road the "ditch" was little bigger than I thought. There might have been a little airborne action involved. Could this have bent or shifted the front bump stop?
That was 6 months ago, everything drives like a dream, no vibes, no wandering nothing. I have also changed shocks and springs a few times since then. Could I have gotten the front bump stop unseated when I installed the springs?
Edit: I searched around and see that this is a problem some times with lifts and caster plates. I am using OME 850 and Witsends 2.5" plates. I could always trim the bump stop but would rather find the right way.
