Frank,
Sorry to hear it's bumping into the AC cutoff. I'm sure it's frustrating with no clear solution and time/money spent on unfruitful PM...
I have 7K cst for my fan clutch to do (read up on tools r us informative posts)
Offroad lights had no measurable effect on cooling - I measured before and after.
My temps flux with ambient temp, like yours. When it's cooler, engine temp drops, etc.
I don't come into the bumping off AC cutoff though.
One thing is that 200F is not hot. Ideally you want an engine to get to 200 as fast as possible and stay there. I guess the logic is that 190F will give you a larger buffer before you hit AC cutoff.
The only time it really strains is on freeway grades (where the fan clutch has no effect, correct?) or heavy trail work where the fan clutch does effect it.
My AC is not ice cold when it's really hot outside and i'm tooling around town. I got the 7k cst to hopefully improve that.
When the engine is working on the freeway grades, temps will build up but stabilize.
I could easily imagine it bumping off 220F+. Going up to Big Bear in 100F+/10%humidity and thin air... people overheat, I see it. That is what I want to avoid but is that a limitation of the cooling system and just drive slower as the solution or is there something wrong?
I had a thought that airflow is reduced with the ARB bumper and lift because airflow is creating a high pressue zone behind the radiator, not allowing normal flow. I was going to add a "spoiler" of sorts to test the theory- might be good to try in this heatwave we have.
Another theory was that the newer HG somehow routed cooling differently so it reads hotter but is normal- however, it seems like a false logic if you are bumping off the AC cutoff.
On the fan clutch- I am confused on which requires what:
-orig oem clutch - requries heavier fluid for eqiv results? or is it the blue clutch that does?
(I read that cruiserdrew went with 6k cst and noticed a stronger fan so I got whatever the shop had- that was 7k cst)
All thoughts and observations... don't really have answers and too lazy to work on the truck in 105F temps!
(oh and fwiw, my temps have been around 195-205F (can go 180-185 in cool weather, on a downhill) and felt it to be normal except my AC as described)
