"So far no one can tell me that the $300 OEM fuel pump is better quality that the OE denso"
The original Fuel pumps were not made by Denso, they were made by AISAN. IDK however if current production OEM/Toyota pumps for an FZJ80 are still made by AISAN, a parts guru @OGBeno may know.
I had the same question years ago when going through the decision whether to buy the Toyota Fuel pump or the Denso Aftermarket part. At that time I talked to someone at Denso who they said that their Aftermarket line of Denso pumps Made in Japan are made in the same factory, in the same production line, to the same standards than any pump that goes into a new vehicle. Only difference they said was that the aftermarket Denso pump may have a different (wider) psi range as it may be designed to work in more than one model/engine type.
FWIW and IME the Denso pump Made in Japan works, so if money is tight IMHO you can't go wrong with a Made in Japan Denso (if you can find a source for the correct pump).
On the other hand, if it came down to any made in Chynah pump versus a made in Japan pump, I'd lean toward the Japan pump (or OEM from Partsouq or Amayama if you aren't in a hurry and want to save a few dollars). Although with shipping from overseas the final price is not that much different than buying from US sources.
