If I can add my $.02 to this thread, since I just noticed & read through the last couple of pages. I replaced my '94 OEM copper/plastic radiator back around March of 2011 because the plastic seam had ruptured. Well, I chose the CSF 2517 because it was all metal, thinking, I wouldn't have to see that problem again. I had just replaced my beloved black hub fan clutch because it had seized, with a new blue hub. Engine temps were not an issue until spring rolled around and then with my modified OEM gauge, it would run a needle width over half consistantly unless there was any incline or load involved, then it would run all the way up to the bottom of the red, depending on the duration of the incline. Then starting last summer, since I started running 35s, if ambient temps were 95+, if I ran A/C at highway speeds 65+, the gauge would do it's climbing trick again. Believing the problem to be the inferior (to my black hub) performance of the blue hub, I lived with the higher temps and butt pucker on grades in the summer time. I even, this spring, got a Landtank modified blue hub, thinking my tuning of my 1st blue hub my be the issue. I noticed a slight improvement, until it got warmer and I needed A/C. So I b**ched about it in another thread and Spike suggested the TYC from his and other AZ 80 owners experience. At 1st, I resisted, because of my dislike of plastic tanks. Well, I decided that what the hell could I lose, to just give the TYC a try. I was doing a cooling system flush and maintenance anyway - good time to try it. Well I ordered the TYC and installed it, all the while fantasizing that the temp gauge would be lower, maybe back to normal - below halfway, maybe....Well, that's exactly what it reads now. 1-2 needle widths under half, normally and climbs to maybe, 2 widths above half climbing grades with the A/C on. Color me convinced - I can't see going back to copper. Another thing to think about that Tools mentioned, current coolant is designed to benefit aluminum radiators. There is nothing in today's antifreeze that will help a copper system. No manufacturers are putting copper radiators in their rigs any more.
