87 FJ60 smogged and stock. Under a year ago replace all coolant hoses, water pump,Tstat, Had a recent issue with a small leak of coolant coming from front driver side. i looked under the top radiator hose and head a pretty steady drip. So bit the bullet and bought a new radiator CSF 2708. Replaced it this last weekend. Everything went back together well. refilled it using the "so spill" funnel. got a lot of air out. turned on the front and rear heat. let it run to operating temp. no leaks! and stayed at temp. drove it the next day. no issue. Drove the this morning got it to operating temp. parked at work turned it off and after about 2 minutes gush of coolant on the ground!!!! WTF. looked at the top to see if I can figure out where its coming from. no residual by the cap or overflow reservoir. It seems like its to full then when it gets to pressure a burst comes out. But where else can it come from??? I know the Water pump has a weep hole. But this is no weep my friend.
