mattressking
10 digits to freedom
Tightened all the clamps coming from the water pump and pressure tested. No leak at this point! So hopefully that was it. Im shocked that those clamps would have loosened up. is there a better hose clamp?
No, the rubber and metal settles in after it heat cycles. A little adjustment is expected unless using the spring clamps as they adjust tension as rubber shrinks/expands.
