just noticed this.
Anybody can point me in right direction of how bad of a job it is ?
common issue?
common issue?
Thank you very muchfairly easy, use flare nut wrenches to break the fittings loose, also change the slave cylinder, then bleed
and brake fluid will remove paint
Thank you SO much
Yes will do bothThis man knows.
Make sure you get correct year clutch m/c. Also if clutch m/c goes slave is right behind so do them both and save time and hassle.
@3_puppies
Separate question. Picking your brain.
I posted in a thread about chrome roof mouldings didn’t get an answer
mine are off - but I have all of them. there is a “plastic insert” that holds them in - any idea where to get them ?
These are not listed as a separate part from Toyota. Do you have a picture what it looks like?@3_puppies
I have the chrome parts. What I gathered is, they just "snap/push" on.These are not listed as a separate part from Toyota. Do you have a picture what it looks like?
