rex in bama
Your clutch master reservoir looks much darker than the brake master, yet they use the same fluid. Suggests that the clutch fluid is pretty contaminated and should be bled/replaced. The clutch master looks old enough to be replaced as well, though, especially if you are having clutch performance issues too.Sorry for my naivety, but can you explain?
Not sure what "looks" you refer too or how new fluid helps?
Both the clutch master and slave are available and are a pretty easy job to replace. Would also be worth replacing the return spring on the slave and the clutch fork boot while you are down there - all still available and at a very reasonable price.
