Clusters, Gauges, Speedo & Odo meters (8 Viewers)
I am far from even beginning to make sense of anything electronic. Does anyone know if there's someone that will receive a cluster and refurb it? I have a 12/74, all stock. All gauges work except the fuel gauge. I've replaced the sender recently, so that's not the issue. I also replaced the connectors, with the exception of where the fuel sender wire hooks up to the back of the cluster. I'm going to pull the cluster and clean up as much of the connections as possible. If that doesn't work, anyone care to point me in the direction of someone who knows what they'r doing?
Just replace the fuel gauge , easy done.
You say, you have a 12/74 all stock, all gauges work except the FUEL gauge.
This tells me that you have a 3rd generation cluster with a barrel connector on the back of the cluster. So no sender wire direct to the FUEL gauge.
The FUEL gauge has a built-in Voltage Regulator which feeds the TEMP circuit AND the FUEL circuit.
If the TEMP gauge works OK, than there is voltage to the FUEL gauge and thus to the TEMP gauge.
Possible faults: FUEL gage, wire between barrel connector and sender, wrong or defective sender.
If you have a voltmeter; check for voltage on the FUEL sender wire on the sender side. there should be 6 or 7V. This voltage fluctuates so if you have a digital meter you'll see some rolling numbers, if you have an analog meter you'll see the needle sweep between 0 and 6V.
If you have voltage it means that the FUEL gauge is OK. If no voltage: replace the FUEL gauge.
If you don't have a voltmeter........
Disconnect the sender wire, turn ign key to on position, touch the sender wire to ground and keep one eye on the FUEL gauge.
If the needle starts moving, remove the sender wire from ground. DON'T WAIT TILL THE NEEDLE REACHES FULL SCALE!!
Rudi
BTW...... is your sender grounded with a White/Black wire?
Should look like this
Rudi
Hey Rudi, yes, the ground is connected. The sender is new as well. I have a digital voltmeter, I'll check it out this weekend per your instructions and see what's up and get back to ya. I greatly appreciate the advice!
Great thread!
I had some trouble with my fuel sender(1970 mod 2nd gen), it showed about 3/4 instantly. I decided to try opening it. Inside it was a bit rusty and corrodet so I took the parts apart, cleaned and rubbed the points. That really help! After reassambly I had to adjust it by the little plasticwheel inside.
The fuel sender works with the same method as the oil sending unit.
PS you don't have to drill of the blade for the cable connector on the top if you are going to take it apart...
It's a 24V cluster if it has a big (dropper) resistor on the back.
There is a text plate OIL FUEL TEMP AMP missing, that's why the gauges look funny.
Go to the 1st page, scroll down and compare that cluster with the years in post #6.
Rudi
Thank you. I didn't catch the missing text plate. I have not seen the back. I am thinking of buying this to restore. It came out of a US FJ40 so it should be a 12v...correct?
Yes.
I opened up my fuelgauge as a last chance to get it working, it looks so simple . Can you tell what can possibly be broken , Rudi or anyone else?
Start with telling what the problem is.
Your Cruiser is pre '73 I assume?
What happens when you touch the sender wire to ground? Does the needle move?
Check the resistance with an ohm meter. Should be less than 100 ohm.
If you have a 6V (SIX Volt) source like an old charging power supply, hook it up and see if the needle moves.
Rudi
It doesn't look burned. Check where each wire is connected to te studs.
Last option is to un-wind the wire to see if it's broken somewhere.
Rudi
Rudi
Is it possible to rewire with some new wire if it is broken, ive tried to measure the resistance on each leadpoint with no luck so i guess broken wire is the case.
@Rudi I have voltage at the sender wire, it rolls between 5 and 9v. In trying the ground the sender wire to make the gauge move, I found it did not. I reassembled and turned the truck on. The gauge went to half tank as it usually does. But.... When I tapped the glass over the top of the gauge, it moved up to 3/4, which is about the amount of fuel that's in there now. So, I Imagine since the sender is new, the gage is getting voltage, all the other gauges work fine and the fuel gauge is loosening up when it gets a few taps on the glass, that the gauge is the problem?
Maybe the needle is touching the face plate?
Rudi
Hi Geaff,
That's the Speed Sensor. Full name VSV or Vehicle Speed Sensor.
It was used in some markets (not all markets) and was part of the ECE (Emission Control Equipment) or ECC (Emission Control Computer) system. It was for gasoline trucks only.
In some other markets it was used to sound an alarm with a buzzer at a certain speed.
Rudi
Sorry for going back years in the thread, but I have the same issue with the speed sensor in my '77 BJ40 from the Japanese market. Could I simply disconnect the buzzer by cutting the wire from the sensor to the prong? My cuts in around 105km/h.
Hi Rudi. Just took the time to read this posting on your instrument clusters. Wow you really know your stuff and have presented it magnificently. So glad that I made contact with you. You have really helped me with figuring out my red "BITZA". I will be sure to refer to your threads and postings before I try to fix or replace any parts.......
