- Joined
- Aug 13, 2011
- Threads
- 2
- Messages
- 45
Kudos to bj40green for posting the wealth of detailed information in this thread! Wow! Very nice!
Hi there all.Ok just read a little but cant find why dose my cluster have the barrel conector and a three pin plug on the back. Thanks to those reply
Diagram two above does not seem to match my original wiring exactly. Most perplexing is the “fusible link” …. I have yet to find it. When the Mean Green alternator arrives, I think I am supposed to replace it and the fusible link wiring run with something rated for a whopping 250 amps x 12 volts. Is that correct? What others wires should be upgraded? The ground from the battery to the chassis looks wimpy, so I'm going to beef it up.
Now that I've followed your link on fusible links … it will be interesting to see if Mean Green addresses these issues. I bet they do not include one of these slowwwww burning fuses/wires that can take years to burn and yet save one's wiring harness. You seem to saying, in no uncertain terms, that the stock amp meter will have to be disconnected. I believe you. I wonder what Mean Green will say, if anything. My experience so far is that they take your money and tell you you what you want to hear. Let's hope it gets better … and not meaner. Of course, my request down the line will be for some electrical wizardry to keep the stock amp meter with a 200 amp alternator. Or I'll ask about after-market amp meters and volt meters properly wired so that no protection is compromised. I suppose a dual battery setup could call for two volt meters … if one is too lazy to stop the vehicle and check the batteries with a $15 voltmeter. Hey, what if it is raining buckets outside and you want to know how the voltage (and amperage) varies with different RPMs and loading. If my amp meter had not told me so much already, I could have had a dead vehicle … in awkward or dangerous situations.
I just discovered this thread and was wondering on an '82 FJ40 50amp ammeter, what are people doing for a fix? Thanks.
