Clunk when starting to move, HZJ78 (1 Viewer)
Calgary, AB
I have been trying to chase down a clunk when starting from a stop, which is not entirely consistent. It seems to me that it happens when releasing the clutch, and is a sound which could be compared to putting the transfer into 4HI and then hearing the engagement when moving, but isn’t quite as loud or violent. When outside the vehicle, the noise seems to come from under the front seats, in the transfer case/gearbox area.
Obviously I cannot eliminate every possibility at once, but assistance in formulating a plan of action from easiest to most complicated would be much appreciated.
Base info:
2000 HZJ78
110K km
The most obvious would be the slip yoke. I greased the h*ll out of it (of course later removing the zerk and driving around to let out excess grease). Of course I simultaneously greased the uni-joints and checked for any play (there is none).
I have also checked the suspension components for loose/missing bolts and cracked or deformed bushings. Nothing standing out here. Being a HZJ78 it has springs in the front, but the leafs in the back are fine and cannot be the culprit.
I have verified the transmission mount looks fine with no deformation and is solidly attached.
Where to go next? Potentially I could remove the rear driveshaft and see whether this eliminates the noise when driving in 4HI with only the front driveshaft providing propulsion.
Video (I know, not very helpful…).
Thank you in advance. 😊
This sounds like something that happens frequently with the 100 series - I used to have it in my LX470.
Culprit is typically the drive shaft, but have also seen it caused by the slop between the hubs and the CV. Are yours manual locking hubs or similar to what is on the 100 series?
Yes, searches seemed to give a disproportionate amount of replies in the 100-series section… 🤣
Front is manual locking hubs. But as with you Troopy it’s not permanent 4WD, so right now I’m chasing the clunk in RWD.
My uninformed thoughts are it's probably the drive shaft. I'd take off the front or rear to see if you can isolate as you mentioned. Maybe the u joints?
Obvious check, and one which you have likely looked into are the suspension bushings. My rears are worn as, cracked and crumbling and I get a gentle clunk when backing up and turning. They are soon to be replaced. Similar noise came from the fronts before I replaced those. Can't say if the noise comes from the suspension, or putting funny load on the drive shafts, but I'm glad I know the root cause of my clunk.
Yesterday I removed the rear driveshaft. (NB: wow, there was a lot of grease buildup in the slip yoke).
Unfortunately the clunk remained. It definitely seems to be coming from the transfer/transmission area, and I noted the other day it also occurred when engine braking and then resuming forward power.
This makes me wonder whether it could be a worn transfer input shaft, as for instance documented by @cruiserdan here. Though I do question this slightly as the onset was quite sudden and the noise is pronounced (nobody seems to have mentioned anything about a clunk before fixing it).
Video of clunk with rear driveshaft removed.
