- Location
- United States
My dad and I have gathered a number of FJ40 parts, many of which we have no need for. I have some second hand history on some of the parts. Unfortunately, many of these parts were stored outside and some have fared better than others. I will try my best to describe each part or set of parts as best I can and make a reasonable estimation of its value- please let me know if I'm off my a$$ on that!
Also, this list will grow as my dad and I have time to take stock and photos. Please stay tuned!
I'll start with what I've been told about each truck: there are parts here from a 1979, a 1970, and a pre-68. According to one PO, the '79 had about 160,000 miles on the clock when it was rolled. The parts stripped from this truck were stored outside for about 15 years. The '70 had very low mileage- I believe he said less than 100k - parts also stored outside, but possibly for not as long? I don't have much info on the pre-68 truck, I just know it was that year range based on parts collected. Later on we'll probably add a few parts from a '62 as well as a '69 and a 1982 FJ60. There's a couple aftermarket pieces as well.
Aftermarket
Confer style auxiliary gas tank. As you can see, it has some surface rust. However, this tank was cleaned out by a radiator shop some years ago and then stored in a shed. I believe the insides are likely ok, but I can try to investigate further if you're interested. Comes with mounting bracket and filler tube. $150
From 1979 FJ40
Steering wheel- no cracks - $20.
Also have turn signal arm/assy available.
Wiring harness. Has some cuts and some broken connectors. Includes emissions computer. $10
Also have several other harnesses and emissions pieces as well as a wiper pull switch with knob in pretty good shape.
Wiper motor cover and other sheet metal part. $10
Hood hinges, wind shield frame hinges, and vent grill. Also have the hood- no rust but has a couple tweaks from the roll over. Will get some pics up soon.
Also have complete front bib in very good shape- with everything including lights
From 1970 FJ40
5 hub caps (I'm guessing from the '70, maybe from the '79 though?) These have some dents and some rust. $10
I haven't looked up most of this, but I have a TON of linkage parts. At least some of these are for the tcase vacuum shift and I'm sure there's some parts from the '70 and some from the '79.
From pre-'68
This is an early wiper motor- haven't tested it yet and you can see that the shaft is bent. $40 as is
I should be able to ID more parts from the pre-68 group soon as well.
Buyer pays shipping from Reno, NV 89511 on all above parts. There's a lot of clutch, drum brake, 3 speed trans, bell housing etc parts that aren't worth much that I'd be happy to give away for price of shipping (or even better- pickup!) before they go to scrap.
Cheers!
Aftermarket
From 1979 FJ40
From 1970 FJ40
From pre-'68
Cheers!
