- Thread starter
- #161
New wheels for the LX. 34ft lbs forged beadlocks from MTD Wheels, with all the hardware and ring.
Wait just a damn minute! Eric, I have been looking for this vehicle ever since I saw it on TEQ website. You built yourself a specimen, truly remarkable.
I deal with this issue when I do things for late model Audis with Bang & Olufsen, it is never optimal to use 4ohms when it requires 8ohms. Lets look at this debacle from a comprehensive angle.
Power Draw: The amp will attempt to deliver roughly twice the current to the lower-impedance speaker. Power output increases, so the amp will push significantly more wattage than it was designed to deliver at that load.
Thermal Stress: This is the core concern. The Mark Levinson amp in the LX470 is a Class A/B (naturally runs hot) design with fixed bias and passive cooling — it was not engineered for sustained high-current loads into 4Ω. Running a 4Ω load will cause: Higher heat generation in the output transistors, potential thermal throttling or shutdown via the amp's protection circuit and over time, degraded solder joints and component lifespan.
Distortion & Clipping: The amp may clip earlier into a 4Ω load because its power supply rails aren't designed to handle this type of load.
Protection Circuit Triggering: The ML amp has overcurrent and thermal protection — you may experience intermittent system shutdown under demanding listening conditions.
After typing all that out, will it work? Yes, it did for me. However, if you go above certain level, you will hear audible distortion and may/may not experience shutdowns. My first set up in my rig was cheapest Alpine speakers off of Amazon, Morel 254 mid-panel midranges and tiny Alpine tweeters which were held by a tape. Everything was 4-ohm ran by the stock amp for years, however, I never ran it at high volumes. Sub amp was the only upgrade in amplification regard. If you are concerned, I can reprint you new brackets and put something that is 8 ohms in them from PartsExpress. Also, I will say this, those Focal Crossovers, I would run my tweeters off of them. If the crossover/processor inside of ML unit fails and gives every speaker the full beans, your tweeters won't be blown.
Try them out as is. If thermal issues arise, it will shut down, and you can re-engage then.
Those Visas will fit in the bracket I sent you, and QTC is outstanding on them; they will be very happy in your doors. Normally, 8-ohm units from Parts Express are not happy with being used in autos due to their Pro-Audio nature.
As for the rear tweeter saga, if you stay with the OEM enclosure, then run a Coax with a tweeter in the center. It will have a separate tweeter hookup.
Amazing looking rig. What are those roof rails??
They're sick, I've been looking for something like that or similar. Black metal and super low profile, I got rid of my prinsu because it sat up higher than I likedIt was Plaidwagon Kyle's old personal roofrack, but I removed the crossbars to fit into the garage. I'm actually getting something else so I can easily pop the crossbars off and on. Once the crossbars come off my current rack, it's pretty hard to get it to pop back on.
+1Easily one of my favorite trucks on here. Nicely done!
