The PO put a plug on the second outlet on top of my Charcoal Canister. The Canister only has 3 ports total- two on top and one on bottom unlike the diagram in my 81 Emissions Repair Manual attached below..
The fuel vapor line running along the side of the truck terminates with a rubber extension hose which should connect to the Canister...but it was left disconnected and venting to the environment.
If I try to connect the rubber hose at the end of the fuel vapor line to the Charcoal Canister the engine dies. Left disconnected and the canister nipple plugged, all runs fine.
Any suggestions? Should I leave it as is, or does this indicate another issue?
