- Joined
- Mar 15, 2014
- Threads
- 13
- Messages
- 1,653
Speaking of Kevin's(Tools R Us) continuing contributions - I recall an idea from him to use some extra long bolts in place of those that hold the transmission crossmember to the frame - to securely hold the entire transmission & transfer case in a lowered position - to gain working room above the TC. I used that idea to help install a new transmission mount. easy - peasy
We have a bin specific for these bolts at the shop, it works quite well and you have a lot more room to work under the truck.
Usually I remove a couple of the bolts in the crossmember, then run the longer ones in until snug. From there, remove a couple more and do the same thing, then remove the final stock bolts and begin lowering the crossmember. We have a few bolts which are threaded all the way and ones with shoulders. If I need maximal room I run in the ones with shoulders last to get as much droop as possible.
