Not on my '97, engages regardless of seatbelt. What year is yours?I don't know if this will help anyone or not, but my CDL won't engage unless the drivers seat belt is latched. Is it supposed to do that? LOL
This was the problem. I did not have the case fully locked when I installed the actuator. Once I re did it it is now working as it should. Thank you gentleman!
OK guys I have read all the write ups on CDL actuator ... mine does not illuminate on the DASH when Tcase is in 4LO but I can feel its engaging ...replaced the indicator switch still no lights... My question is if I don't fix the CDL ACTUATOR with the indicator Lights OFF ....can I still go wheeling? It still engaging on 4LO...what could go wrong with CDL actuator BAD and no indicator lights on DASH?? thanks
There are 3 indicator switches on the transfer case. Which one did you replace? Was it the one on the front of the transfer? Did you bypass the the switch by shorting the pins on the wiring harness connector together? That should turn the dash light on no matter what the state of the lock.
Yes you can go wheeling if only only the light is not but be aware that ABS will remain active which could be a safety issue. Also if you forget that the CDL is still locked when back on the pavement that would cause "windup" of the drive line which could cause damage.
Just did a set of low range gears yesterday. There are 4 bolts holding the actuator in place, plus a small vent line. It is very hard to get your hand up there without lowering the transfer case. It is also hard to break the actuator loose from the main case as there are no real good points to lever against.
Okay thanks! I've not lowered the transfer case before but have all the tools to do so.
What is the proper procedure to lower the transfer case? Id like to tackle this actuator job but also want to do it properly and safely in terms of lowering the transfer case to get at the actuator.
How far can I lower the TC?
