Can you still purchase an OEM charcoal canister (Denso Vapor Canister)?
@jbstrong01 said "I have the Dorman evap installed!"
Which Dorman part number or was this a typo?
no typo :D Amazon $65 delivered in a day!
Dorman 911-261 Vapor Canister
Update on the Dorman so far, absolutely ZERO noise out of the gas cap, when you unscrew it it's like new. ZERO noise. Truck runs fine, now codes, no gas smell, seems to be working great. Now if I could only figure out the noise at the bell housing! :)
noise in bell housing? :wrench:
I'm thinking...
Upper Reciprocating Dingle Arm Bushing, or,
Knuter Valve, or,
Headgasket:bang::clap:
I'm thinking...
Knuter Valve, or,
I cut the URDAB out, put in my Jeep, plugged the KV with an old plug from my flux capacitor and hoping it's not the head gasket, would rather it be the flexplate
I have the Dorman evap installed! Took all of 40 min and I have both brackets connected, the lower wiring did not impeded the install. I pulled out the breather hose and saved it. The OEM (25yr old) unit was HEAVY! 56oz's wreaked of gas and the new one was 25oz's. I weighed it! I also have video that I will post to my YT channel when I get the chance. Dorman unit works fine, starts fine, runs fine, no codes, will keep the thread updated.
Update after a month ... working flawlessly!!
Replacing mine with the Dorman 911-261 since its $20 cheaper than the ACDelco 215-153.
Just wanted to confirm, you guys did not extend the breather tube on the bottom to reach the top of the new filter, correct?
My AC Delco is temporarily and the breather wasn't extended. However, mine is temporary until I get my 105 canister fitted up.
Just checked: I've had the VC-120 canister in since 2015, that's three emissions inspections.
:cool:
What model vehicle does the VC 120 fit. I can’t find it by or number.
I'm currently running the ACDelco 215 which is a dead-on replacement from the vc120 that was in there from the PO.
The acdelco's been in there from when I tore out my 1fz almost a year ago for a full refresh. I've had no issues with the ACDelco it's been great and on long trips I'm guilty of pushing in an extra two gallons of fuel :hillbilly:, which can saturate and shorten the functional lifespan of the charcoal filter.
About the same time as the 1fz refresh I sourced a Land Cruiser 105 charcoal canister which I lent out to a land cruiser pro hero for some R&D. This might result in a nice factory style solution for all of us.
Is there any reason to choose the 105 series canister over the Ac Delco to Autozone? I'm surprised there is no drop in aftermarket or other replacement since it's an emissions control item.
@BillyGoatMTB this restores hope that I can one day reinstall my 105 canister that's sitting in the garage...for now, an unhooked breather tube with a small filter on the end has been working perfectly for eliminating the tank pressure. Excited to see what the LC HERO comes up with. 😎
@motormayhem the Cruiser community is a fickle, OCD, mildly addicted to OE Toyota parts bunch...we like our OEM solutions. 🤣
Haven't heard any updates from the LC hero but I can report my AC Delco is working fine, I'm not a fan of the bottom vent design, the plastic bowl bottom got hot in the summer and warped.
The 105 canister is on my project list, I'm thinking about making up a bracket for it with some aluminum.
Maybe it's the OCD in me but I like factory parts, the AC Delco works but not being a factory part kinda bugs me :hillbilly:
