Cam's FJ60 Gets Sprung
Is it:
jarbridge-jpg.1094478
or...
image-jpg.1094492
I'm submitting that request for approval at the next board meeting.
Anybody need some 285/75/16 Trxxus's? They're famous... they've been to the Rubicon and made it to Jarbidge.
how many tarz and how many doll hairs?
I'm already planning the 2017 return to Jarbadge. I want to spend more time in the NY Peak area and Middle Earth, and Windy Gap. You can keep your Owyhee Desert though.
What happens if at the board meeting, the request for spending is not approved?
I want to say when I got the 315/75/16 AT tarz last yeah, it was near 1000 doll hairs and maybe a hair over.
That too.
Middle Earth was spectacular! But... baja???
That too.
You forget that the NorCal crew does about 6 or 7 of these trips every year, so they'll hit both. Plus Death Valley spring & fall, Rubicon a few times, and then maybe Dusy.
I need to retire so I can hang. Or maybe Andy will hire me as a personal barista & Coleman/Cruiser turd polisher.
I thought you were retired and had the Mrs doing the work?
Update after driving it for a few days...
After reading about residual valves, their purpose, and how they work, it sounds like I need a 10 psi valve to run drums in the rear to keep the shoes pushed out. Otherwise you have to do a quick double pump to get rid of the slack. I've been doing that, and WOW! Firm pedal and it stops really well with a good, progressive pedal response.
This is temporary until I get the FF in, so I'm not putting any effort or parts toward the drums. The discs are considered by most to be an upgrade, so I expect it will at least stay the same, which is already quite an improvement over the 60 brakes.
The bad (not really bad, just data):
The 863/850J combo is a hair too firm for a DD only truck. I'll bet it is the equivalent of the Slee 4" on an 80. This should be perfect for fully-loaded week-long trips into BFE. I may explore medium springs in the future. Overall, though, it is similar to the heavy leaves, but smoother and with softer and squishier initial movement.
I've got some weird noise like something is loose or making contact underneath/outside the truck going over bumps. I can't find any play in the tires/axles/suspension, but I haven't had time to crawl under and inspect everything. I suspect it is the worn out body mount bushings and I'm just hearing the entire truck rattle. Replacing those is on the short list. This is still a 30 year old truck after all.
Caster is drastically improved after putting the plates on. It might could use a touch more, but it could also just be the increased bump steer from the drag link angle (I had flat drag link geometry previously). It is not scary to drive, though, and other than the bump steer, not much different than before.
The good:
It drives and tracks straight down the road, so I think we got it fairly square. Hopefully it looks that way to those following me.
The increased brakes and better suspension are a much better match for the V8. It feels like a more balanced vehicle now. The handling and brakes are a better match for the increase in power. It does not feel any more tippy in the turns, but actually more stable, even with the increased height.
Steering feels more natural now. It is much more manueverable in parking lots, due to the Ackerman geometry built in to the 80 setup. Luke (4x4Labs) mentioned there was not enough room on the standard crossover arms to get ideal angles. Anyway, it feels like I could turn around inside a parking space. This should really pay off on the trail. I'm also running the correct backspaced/offset wheel for the knuckle now.
The 80 PS box does have more power than the 60, but since adding caster and a steering damper, it is not quite the increase it seemed previously. No complaints though. It seems like it has a quicker turning ratio. Anybody know?
It looks like I can go up a tire size (to 35's, which I the biggest I want to go anyway) without having to cut anything or sacrifice much, if any, up travel. The shackles on the front leaf springs move the tires forward under compression and shove them into the fender. With the leaves, I had it set up where it would just contact if fully stuffed & fully turned at the same time (with 33's).
The coils move pretty much straight up and down, so a bigger tire fits more easily. I should be able to fab extended bumpstops to keep everything happy when fully stuffed & turned.
Next up is getting the permanent FF rear rebuilt and under the truck and getting some new tires. Hopefully both will happen in the coming weeks.
The axle is getting the full treatment - all new bearings, seals, parking brakes, general brakes, and lots of new nuts & bolts. Should be pretty when it's done.
That's a good report/update.
As I said on my swap, no need to pump the brakes or have a residual valve, so I think you're correct to wait on the discs. Enjoy your nice parking brake now.
Stay with the heavier springs. You are going to load it down with espresso gear and cooking pans so you'll need the heavier springs.
Still looking for that hub sticking out of the rear wheel.
We were tryna get outta the chop shop as fast as possible before the cops showed up, so we didn't salvage the SF parking brake cable. We spent 20 seconds trying to figure out how to disconnect it from the handle before cutting it.
One of my sponsors stepped up and sent me an 80 cable. Details when I get to it.
I'll reexamine the springs after I figure out the noise & replace the body mounts (the noise detracts from the ride). I figure even if I get mediums, I'll keep these springs to swap in for trips (sorry Bossman!) That's part of the dialing in process though. I feel kinda lucky that these will work as-is.
The FF and tires have to wait for me to get my next monthly allowance. I'm about to get cut off for a while :D
I may have accidentally discovered an 80 rear brake caliper substitute.
I bought the cheapest calipers I could find on eBay to turn in as cores towards parts-store 80 calipers, since my housing had no brake calipers or rotors. Those turned out to be from a Sequoia.
I pulled them out of the box yesterday and they looked identical to the 80 series calipers in every way. (I've since acquired a complete housing w/brakes that I can compare with).
AC Delco even shows the same caliper being used in both applications. Autozone shows different part #s though. That's as far as I've dug into.
I'll try to bolt them up later, but I believe they are a direct fit.
